“Your Vehicle is not responding. If this continues, shutdown QGroundControl, restart your Vehicle letting it boot completely, then start QGroundControl.”
This usually indicator a communications hardware problem that there is vehicle->qgc communication traffic, but the qgc->vehicle communication traffic is not working.
I’ve been able to flash the firmware using either without trouble. I also did the bootloader without any trouble. I just flashed to rover then back to copter using Mission Planner without trouble but the problem persists.
Yes, when using QGroundControl, I still get the
"“Your Vehicle is not responding. If this continues, shutdown QGroundControl, restart your Vehicle letting it boot completely, then start QGroundControl.”
No. I never got it working. Setting BRD_SBUS_OUT to “1” seems like all I should need to do, but didn’t work. Changing the SERVO_FUNCTIONs on channels I was using didn’t change anything either.
