Hi guys,
I’ve been hearing about the XUAV Talon flying very stable for a long time. I decided to give it a try and recently bought a standard XUAV Talon as well.
The aircraft has a wingspan of 1718mm and has a V-tail.
I want to use these avionics that I have on the plane.
Pixhawk Cube
Here3 GPS
6S 6200mAh Lipo battery
80A BEC ESC
RFD900X telemetry
QX-Motor QA42220 Brushless motor
13" APC Propeller
Since the area where I fly is not very windy, I do not plan to use airspeed sensors and I wanna make autonomous missions with the aircraft.
Take-off weight will be about 4 kg.
Despite this take-off weight, the motor I have is overpowered for this plane. When 6S battery and 13" propeller are used, it can give about 5kg thrust with 100% throttle.
If anyone has used XUAV Talon before, which parameters would you recommend to set during the setup of the aircraft?
