Solid-solid batteries have higher energy density and longer battery life. For the convenience of use, smart Solid-solid batteries are becoming a trend.
Smart Solid-solid-state batteries have the following characteristics (take XTurbo for example):
Intelligent BMS: XTurbo intelligent drone battery is equipped with an advanced BMS (Battery Management System), enabling users to monitor critical battery information in real time during flight missions, including voltage, current, temperature, remaining battery percentage, instant power, and more. This ensures enhanced safety and peace of mind throughout the flight. Ardupilot and PX4 compatible: X-Turbo intelligent battery is fully compatible with any flight platforms running Ardupilot or PX4 firmware.
Smart Charging: During the charging process, the battery continuously monitors its status and provides alarm notifications for overvoltage, overcurrent, and overheating.
Smart Storage: When the battery is not in use for an extended period at a high charge level, it automatically activates the smart storage function, discharging to the storage voltage to ensure safe battery storage
Auto Sleep: When the battery is turned on but not in use, it will automatically enter sleep mode and shut down after 3 minutes if the charge is high, or after 1 minute if the charge is low, in order to conserve battery power.
Smart Balancing: The battery automatically balances internally, keeping the voltage difference between cells within 20mV.
Extended Cycle Life: Thanks to the high-quality cells and excellent smart management capabilities, the battery achieves a cycle life of up to 400 charge/discharge cycles with proper usage.
