After taking off the directions of copter is completely wrong …
Im using matek m10 gps with compass
I also used m9n matek …i tried to desble external compass but still the same
Any suggestion thanks
Please define “the directions are wrong”.
Is your roll reversed? Is your pitch reversed? Is your yaw reversed? Is simple mode or super simple mode activated?
Did you calibrate your RC before flight?
Did you follow the methodic tuning guide for the setup?
Please post the .bin
log file of the flight in question.
At first take off after compass calibration …the directions are right
Once I bring the drone above me the direction change
Pitch start to be roll …
Without further means to investigate, like a flight log for example, hat sounds like a simple or super simple error to me.
What flight mode were you flying in?
log file of the flight in question, or at least a .param
parameter file.
Ok I will send you the logs …thank you
RC mode (1,2, others) setting and MP calibration and verification ensure everything works in order as expected.
Thanks
But the stick mode is 2 and all sticks are calibrated well
The compass tab is confusing
Maybe im messing somthing with my compasses
I even tried to remove external compass and used only one internal
