Write-protect parameters
I am concerned about the possibility of tampering or simply changing a parameter by mistake. Anyone with brief access to Misson Planner or any ground control station will be able to modify a parameter that could be fatal.
Is there a way to write-protect the parameters or part of them?
Cheers
Maybe it can helps : APJ Tools for Custom Parameter Defaults — Dev documentation
Try checking the box.
Thanks, I did not know that
That is also great. Thank you
