WOBBLE AND HEAT ISSUE
I have built a hexacopter out of a cheapie hex thorax frame and spare bits but I have a few issues that I am trying to resolve. The build details are at the end and the link is a test flight log.
Issue 1. A pretty good wobble which does not abate and seems to be exacerbated by very slight amounts of wind. The Pixracer board is mounted on the frame using rubber 3M vibration mount screws.
Issue 2. Motors 1 and 2 (the middle left and right) get very hot. The test flight was barely a minute and they were just able to be touched. May this be due to the constant corrections required for the wobble. Other motors are warm but not significantly so. ESC’s also seem unaffected.
Issue 3. Float ?. A bit harder to explain. The craft maneuvers well and is responsive in pitch, yaw etc, however, throttle responsiveness when decreasing the altitude is slow. It’s like the props have so much lift that it takes a bit of time for the rotation speed of the motor to slow enough to allow it to lower the altitude. The effect is reduced when using 5x3 props as opposed to 5x45 BN props.
Pixracer R14
4S 5000mA Lipo
EMAX RS2205-2300 motors
ESC = TURNIGY MULTISTAR 40A BLHELI-S REV 16 ESC 2~4S V3 (OPTO).
ESC Settings as shown below
Startup Power = 0.5
Temp Protection = 140C
Low RPM Power Protection = yes
Brake on Stop = no
Demag Compensation = Low
Motor Timing = Medium
Other settings: MOT_PWM TYPE = Oneshot125
Weight = 1150gms
