I immediately entered only optical flow into EKF 2.
Certainly velocity (VX, VY VZ) of my quad is presumed.
I lifted my quad and confirmed it!
However, the position estimate was still 0.
Integrate Velocity to get Position.
I estimate that position estimation is not performed because the velocity data obtained by optical flow is inaccurate than the velocity data obtained by GPS.
I want to ask now because I am not in an environment that can let my quad fly.
Is it possible to input the target velocity using “SET_POSITION_TARGET_LOCAL_NED” in order to move my quad in GUIDED mode?
You can right click on the Map on Mission planner and set home == Set EKF Home
The vehicle should appear on the map and if you ZOOM full you can validate dispjacement by moving Quadcopter around holding it in your hand
