The problem is when I test the full throttle motor with full battery 24.6V it start with with good thrust.
After 5 min the motor is slow down to the middle and continue in that position , when I reduce throttle by RC to 0 and then full it return back to good throttle for few minuets about 5 min then slow to the middle.
I don’t know what is the reason of that ?
When I try using Li-po battery I get the same thing maybe worst after about 10 min the throttle is down to zero.
Hope I can find any solution for my problem…
Regards…
I have had some experience with the big lithium Ion battery’s and they do not perform well at high current draw.
If you have a look at your logs you will probably see that the voltage drops greatly when under load.
Do you have a voltage failsafe set and what voltage?
@iskess I will do that and post the graph here ,
but I need to know the voltage and current in the log file under which group logs ? coz I found many items in the log list information ?
what is the recommended battery ?
I test Li-Po also the same problem it is reduce then off ,
I am disabling the throttle failsafe until I solve my problem …
