I would like to know a simple thing : what is the most commonly used RC with Ardupilot ?
I have read the documentation, but they does not recommand anything.
For example, I used to fly with Spektrum, but I have some problems with it (RC loss happens regularly).
Good day, me im using as rc the taranis x9d plus, but you can look also for the taranis qx7s…, both are with open tx firmwares and the setup it’s simple.
just be sure the version you need coz there are two versions… if you are in Europe you. must check for EU version and EU receivers… for other countries you must check the correct firmwares as for receivers
As receiver you can use the the frsky series… x8r…x4rsb… etc
A Radiomaster TX16S. Out of the box it will bind to most RC systems including your Spectrum Rx’s. Won’t to Frsky ACCESS but all ACCST Rx’s. Brilliant Transmitter.
I have used Flight Deck since the early days before the pass through protocol was added to ArduPilot. Back then I had to run a custom version of the firmware.
Which flight controller is better the ardupilot or pixhawk4? I’m trying to make a a tilt rotor hybrid plane that has wings and uses three motors intend of 4 motors . And yaw vectoring up front. Thanks if anyone can answer to my question lol
I’m doing 3 rotors two tilting in from for forward transition and hover and plane hybrid I’m about to buy the pixhawk4 that has the ports I need. I’m trying to figure out if tyrannis 9 is a good choice cause it will use 8 channels total
ok…, in frsky Web dite you will find the correct firmwares for your radio but you must check first the correct firmware, if you are i Eu you have to flash Eu firmware for your radio and also the Eu firmware for your receiver, if you are USA you must flash the firmware for radio and if the receiver is already for that you don’t need
Also I’m building a remake of the econvergence thus I’ll be using elevon to keep things cheaper and lighter I have to cut up the ranger 2000 make it a delta wing using the original wings take a miter saw cut a 45 ° angle so the wings can clip on the right sides and I ordered 45 degree with center 3d printed connectors. Sighs this is yet a challenging aspect of customizing my plane. The elevator will be fixed so as the rudders to I’ll have to get another pair of tail parts.
well, sbus and spectrum are different protocols, the radio you need depends also about the way you want follow…keeping the same standards for all your projects… and future developments.
