Which Flight Controller should I choose?
I need suggestions on which flight controller to choose.
So basically im building a fixed wing UAV which gonna have 2 missions to do:
First mission is to fly autonomously between two poles like drawing an infinity symbol.
Second mission is to drop 2 loads on two different areas. These are gonna be red, square shaped areas with 2x2meters and 4x4meters dimensions on the gorund. The UAV is gonna detect these square and drop 1 load to each.
I will be using raspberry pi 4 8GB for image processing part and i was thinking of using pixhawk 6C as a flight controller. For the competition that im gonna take part i should meet the reqiurement of “minimum cost, maximum efficiency”. So im just not sure if any other flight controllers like pixhawk 4 or Mateksys F765-wing or any other FC would be enough for this project.
So which flight controller should i go with?
The UAV is roughly gonna have this look
Those are both EOL. Don’t limit yourself, use an H7 based Flight Controller like the Pixhawk 6C you mentioned. There is a mini version of that also. There are many other H7 based flight controllers that will suit.
What about the GPS. Do you think M8N gps would be precise enough for these missions?
F405 based FC and an 250-class M10 GPS + compass, 250 is the size of the ceramic antenna 25x25mm.
There is no reason to select an F7 or H7 FC for a traditional plane, especially if the heavy lifting is done by a companion computer.
Maybe if scripts are needed to complete the tasks … Today I would use a Matek H743-WLITE, which should last for some time.
Actually im still in the beginning of the project and idk if the drop mechanism should be controlled by raspberry or FC
You don’t need a RPI to run a drop system. At it’s most basic it can be done in a mission plan, but if you want to get fancy and maybe take in some variables then Lua scripts could also be a viable solution. To run Lua you’d need an H7 board (the H743-Wlite is a good suggestion), but if you decide to just go with mission plans F405 will do the trick.
