Where is the most appropriate RFD900X antenna's position on the fix-wing and vtol aircraft.?
I very confuse about the correct position of rfd900x antenna which is set up on aircraft
which one is the most appropriate RFD900X ?
  1. set up both antenna on left/right side of fuselage. (one side vertical and other parallel)
  2. one vertical on top of the aircraft and other vertical from bottom of the aircraft.
