I’m using a Pixracer from mrobotics.
For manual flight mode where do I set the exponential values for aileron and elevator in an elevon setup?
In the transmitter? Or is there somewhere in the parameters in which to set expo?
Thanks,
Paul
Thanks,
Paul
Solution is here : Elevons not available on Arduplane?
Thanks kikislater,
There was no mention of exponential, so I’ll just put it in the transmitter.
Paul
There is no expos framework in Plane, since the autopilot takes care of low-level inputs. For manual flight, as you correctly guessed, you should configure your transmitter in the old-fashioned way.
Thanks for the explanation George. Paul
