I’m trying to get faster rolls in stabilize.
ANGLE_RATE_MAX is no longer in the list of parameters.
What limits the rotational speed in stabilize now? Changing the acro_RP_P doesn’t change it. Acro_Y_P does change the speed of yaw in stabilize… So, I guess there is something else limiting the RP speed in stabilize.
The “fast” setting is just a guideline. You can still set it higher if it is limiting you below your desired performance, even above the 180k range that the documentation suggests.
