hello , what happen when i chose quadplane with all four motors tilting ?
in fixed wing mode did the 4 motors run to push airplane forword ? or just the 2 front motors ?
Hi Aziz,
I found a post from Tridge from last May 2018 which should answer your question.
Cheers!
Thanks for response will try like that .
Hello @GregCovey
my quad is tilting to one side…can u pl tell whats the problem. below is the log:
Log File C:\Users\PRASHANT SOOD\AppData\Local\Temp\tmp123C.tmp.log
Size (kb) 108.5234375
No of lines 2133
Duration 0:00:01
Vehicletype ArduCopter
Firmware Version VDD_5V_PERIPH_nO
Firmware Hash 4fcfa4b2
Hardware Type
Free Mem 0
Skipped Lines 164
Test: Brownout = GOOD -
Test: Compass = WARN - WARN: Large compass offset in MAG data (X:377.00, Y:43.00, Z:38.00)
mag_field interference within limits (9.07%)
Test: Dupe Log Data = GOOD -
Test: Empty = FAIL - Empty log? Throttle never above 20%
Test: Event/Failsafe = GOOD -
Test: GPS = FAIL - Min satellites: 0, Max HDop: 99.99
Test: IMU Mismatch = NA -
Test: Motor Balance = UNKNOWN - ‘OCTAQUAD/X’
Test: NaNs = FAIL - Found NaN in CTUN.TAlt
Found NaN in CTUN.DSAlt
Test: OpticalFlow = FAIL - ‘FLOW_FXSCALER’ not found
Test: Parameters = FAIL - ‘MAG_ENABLE’ not found
Test: PM = UNKNOWN - No PM log data
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = UNKNOWN - No CURR log data
This poster above is spamming to several random posts with useless info about his quad.
