hi there…
I made a Hexacopter from the Pixhawk 2.4.8. and properly calibrated it. the all the motors and propellors are in correct direction. But while takeoff if i move yaw to left the drone get rotate by a left direction, but it will continuously be moving in same direction even if I release the yaw. once i move yaw stick left and release it, the drone continuously rotate the left until I move yaw stick to right. one i move yaw stick right and release it, it will continuously rotate the right, even if the stick is its center position it will not stop rotating.
due to it i can’t controll the drone and it got crashed. Also, the Altitude and Loiter mode is not working.
when i pull the throttle above 50% the drone got always crashed.
please give a solution if anyone have. i am beginner in this field.
