now “preflight_calibration” in mission planner does both gyro calibration and air speed calibration. I want to seperate the gyro calibration and air speed calibration
Reason :
in the above link, you can confirm that airspeed sensor should be calibrated manually before every flight.
so, we have to press “pre-flight calibration” button before every flight.
the problem is, “pre-flight calibration” button also calibrates gyro and acc.
I will operate VTOL on moving ship, in the deep ocean(south pacific). because there is no place that calibrate gyro and acc, I have to turn off automatic calibration.
but airspeed sensor calibration forces me to do gyro and acc calibration on shaking fishing vessels.
I have programming knowledge but I hope I don’t need to write lua script or other plugins…
