Before start, my mail configuration is as follows
FC:speedy bee F405 WING
GPS:BN880
VTOL MOTOR: EXMAX 2807 1300KV
ESC:DLRC 4IN1
REAL MOTOR:JF2814 700kv
FIRMWARE: Plane 4.4.4
I converted a delta-wing into a VTOL,It has flown successfully several times.
The last time I took off from the roof of my car, there was a fault message as the plane took off:
EKF3 IMUO MAG0 ground MAG ANOMALY,YAW-Reakugbed,
I did not pay attention to it at that time and chose to continue flying. During trans to FIX wing mode, the plane suddenly turned over. I switch back to QLOITER mode, but it could not became stabilize, and the plane crashed.
Unfortunately, the plane crashed, but I installed DJI air unit on the plane, and the video has OSD data throughout the flight. And the flight controller also recorded the entire flight process. I hope some one can analyze what is the reason for this crash, and write out the entire process of analysis, not only to find out the reasons for developers to improve, but also as a case to learn from each other.
VIDEO:
log file:https://drive.google.com/file/d/1R4iN4i-KvPauPrdcfT0qclxSHEZwXxIF/view?usp=sharing
I also checked the forum and found that many people have encountered this malfunction, but in the end, it seems that the specific cause has not been determined
THE GPS MODULE HAS BEEN PLACE FAR AWAY FROM THE POWER WIRE.
