EKF3 IMU0 MAG0 ground mag anomaly, yaw re-aligned
Hello! To begin with, I will tell you a little about my aircraft.
My frame size is 800x800x500mm.
I use Cube Orange, Here3 GNSS, Hobbywing XRotor Pro X6 motors and 2 LiPO 22000mah batteries.
I’ve been flying steadily for a few months, but recently I’ve been getting the “EKF3 IMU0 MAG0 ground mag anomaly, yaw re-aligned” error when climbing. When this error occurs, my drone behaves very unstable. After I climb to a height of 10-15 meters, the compass is recalibrated and the drone behaves stably. I tried to solve this problem by replacing the compass with a PM3100, and installing a helix antenna. Then he tried to move the compass to a distance of 15 centimeters from the power wires. Changed the value of the parameter “EK3_MAG_M_NSE” to 0.07 to reduce the sensitivity of the magnetometer. But all this did not help.
I will leave a video of one of my flights and a log file. I will be glad for any help
https://drive.google.com/drive/folders/1_ph5LgvXjAAS3ioRQrogPOCklhygfLG_?usp=sharing
Update to the latest firmware, 4.3.3.
Both compasses are reacting directly to the throttle output, so they are showing signs of interference. Not just the compass, but look at how the wires go to and from the compass to see if you can get those away from the power leads.
If you can do a flight for a few minutes with several 360 degree turns then you can run MagFit and get an updated COMPASS_MOT offset.
Thanks for the answer!
I tried to use different firmware starting from 4.3.0
I tried to move the compass away from the power wires (10, 15, 20 cm), but it did not help.
Once the drone gains altitude, it stabilizes and I can fly, but the climb is terrible.
I’ve noticed that this doesn’t happen everywhere I fly, but most of the time it does.
I understand that the reason may be the place where I fly. But I need stability. How can I achieve it?
You have an hardware issue.
Please use ArduCopter 4.3.3 and fix the issue.
Do not waist your time with 4.3.0
I have same problem, I am using pixhawk cube orange 2 22000mah lipo battery and X8 Pro Motor with X8 quadcopter configuraiton. Can you fix this problem?
same problem to me. take off in alt-hold fine and after 15 second it start to bounce and EKF ground mag anormally apear. i will try to update to 4.3.3. i will inform you. (octoquad black cube arducopter 4.0.3)
Please do update to ArduCopter 4.3.5
hi, have you solved the problem? i use 4.1.3 with the same problem
