Hello everyone, greetings from Colombia. I’m new to the forums but not new to using APM and PIXHAWK. Today I turn to the experts because I’m having trouble getting the VL53L1X sensor to work properly. It’s not measuring beyond 50cm. I’ve reviewed the documentation and managed to call the sensor, but it’s not functioning correctly. I’ve also tried it on an Arduino and the sensor works perfectly. Can anyone shed some light on this? Thanks.
A lot of the VL53L1x lidars I have bought have had less than ideal range, the most reliable version I have found is the tof400c vl53l1x, it’s a little more expensive, but I suspect they have better quality control.
what surface are you testing against, darker surfaces are more difficult to range.
I tried that configuration, but the issue persists. It’s worth noting that I’m on Windows 10, using version 1.3.79 of Mission Planner, and firmware version 4.44.
