Hi
I am using ardupilot with gazebo so I have iris drone in gazebo env. I want to take off the iris without gps so I have robust odometry topic then I publish the odometry topic to /mavros/odometry/out name and the frame id and child ids are correct. I face the error when odometry recieved the ardupilot it shows Visodom: Out of Memory. So there is no hardware all things run in docker container what the point I couldnt understand with the out of memory error. Some sources advice to use visodom used firmware update but again this env is gazebo. ? How can I solve the problem ? When I use px4 autopilot publishing /mavros/odometry/out is enough to provide odometry to the drone
