The screenshot I take from the Doc of Telemetry.
I had that problem while using QGC. After changing the battery the Vehicle position is not updated. I need to disconnect and reconnect my Skydroid T10. Is there anything I can do to solve this?
You need to set the SR* parameters on your telemetry serial port. Just like explained above
@amilcarlucas Thank you for clarifying. the drone I got used telemetry2 and the SR2_Position is set to 3. change it to 4 Hz works.
