UWB fake gps(GPS_INPUT) can not hold position in loiter mode
Currently I am testing uwb system with ArduCopter, using sky viper fly indoor, I am inputing the pos value with mavlink (GPS_INPUT), params change with GPS_TYPE to 14(MAV), the uwb pos error is ±15cm and fresh rate is 5Hz, below is the mavlink input code with DroneKit
                            fix_type        = 4
                            sat_visible     = 20
                            epoch           = 315964782
                            cur             = datetime.datetime.utcnow()
                            ts              = cur - datetime.datetime(1970,1,1)
                            epoch_sec       = ts.total_seconds() - epoch
                            time_week       = epoch_sec / 604800.0
                            time_week_ms    = (epoch_sec % 604800) * 1000.0 + ts.microseconds*0.001
                            time_us = current
                            #  ignore_flags = mavutil.mavlink.GPS_INPUT_IGNORE_FLAG_VEL_HORIZ
                            ignore_flags = 0
                            res = get_location_metres(22.9514009, 113.8685862, pos[1], pos[0])
                            lat, lon = res[0], res[1]
                            alt_amsl = pos[2]
                            hdop = np.linalg.norm(np.array([eop[1], eop[0]]))
                            vdop = 2.0
                            vn = vel[1]
                            ve = vel[0]
                            vd = vel[2]
                            spd_acc = 0.1
                            hor_acc = 0.1
                            vert_acc = 0.02
                            print(lat, lon, alt_amsl, vn, ve, vd)
                            msg = vehicle.message_factory.gps_input_encode(
                                                 time_us,       # time_boot_ms (not used)
                                                 0,                 # gps_id
                                                 ignore_flags,      # gps_flag
                                                 int(time_week_ms),
                                                 int(time_week),
                                                 fix_type,
                                                 int(lat*1e7),
                                                 int(lon*1e7),
                                                 alt_amsl,
                                                 hdop,
                                                 vdop,
                                                 vn,
                                                 ve,
                                                 vd,
                                                 spd_acc,
                                                 hor_acc,
                                                 vert_acc,
                                                 sat_visible)                # Satellites visible
                            vehicle.send_mavlink(msg)
The problem is when I take off the drone in ALT_HOLD, the switch to loiter mode, the drone just fly away in one direction, which value should I look after in data flash log to figure out what’s wrong
dataflash log is here https://drive.google.com/open?id=1-TVg_3DwVpq1Z2DHzt9YvCD3P_PxmC4k
params is here https://drive.google.com/open?id=1myIlEHI8MG23_qE1BoSvtzp3GO44jJl4
Hi. Did you find a solution to the problem? I have a similar problem now.
