in order to add proper stall warning only when flying, how can I determine that the plane is actually flying? (not to trigger stall warning unless actually flying)
Have you seen @magicrub’s stall detection code?
Note that it is extremely difficult to tell 100% when you’re flying in a
fixed wing.
What you probably want is the extended_sys_state message, which I
implement here for Plane:
That was hung up on tailsitter transition logic IIRC.
