I’m looking for a way, that I can control external RGB LED’s over the PWM outputs. The goal is the External LED to copy the NTF Status LED condition. Is there a way, that I can tell the ardupilot to output PWM for RGB leds on some of the SERVO_OUTPUTs.
Thanks in Advance
External 5v power supply for ground and positive. Connect signal and ground from led (neopixel,rgb,etc) to aux 5 or 6.
Configuration page. Change parameters for NTF type value to whatever kind you have… change the aux number you used (aux 9 for example) to neopixel value. reboot the Pixhawk…
