Using a custom MAVLink message in Mission Planner
I have been trying to create a new MAVLink as described in Adding a new MAVLink Message which I did and managed to recompile successfully the ArduCopter using the command ./waf copter. (I assume this will generate the firmware that I will use later on mission planner).
As I understand from various posts I now need to recompile Mission Planner by adding the same message to ExtLibs\Mavlink\message_definitions\ardupilotmega.xml and update mavlink via running regenerate.bat.
My question is how to use the copter I compiled before?
Many thanks,
Greg
Upload your firmware into a FC and check in the MAVLINK Inspector tool of MP if your message is arriving.
Bruno thanks for your reply.
I found the answer here Connecting Mission Planner to SITL in VirtualBox.
Basically sim_vehicle.py --console --map --out=udp:XXX.XXX.X.XX:14550 does the trick.
Many thanks,
Greg.
