usb is not show in com port in my custom flight controller after flashing bootloader hex file
Hi all, I’ve compiled the Nimbus STM32H743 bootloader (my custom flight controller )and uploaded tools/bootloader/board_bl.hex via ST-Link using STM32CubeProgrammer, and the bootloader flashes successfully, but my USB is not detected. I am trying to use High-Speed (HS) instead of Full-Speed (FS) and have configured the PLL for a 48 MHz USB clock (OSCILLATOR_HZ 25000000, PLL_M 5, PLL_N 192, PLL_Q 20). My hwdef sets PB14/15 for OTG_HS_DM/DP, disables VBUS sensing (HAL_USE_USB_VBUS_SENSE 0, HAL_USB_FORCE 1, USE_VBUS_PULL_DOWN), and currently uses the internal FS PHY (STM32_OTGHS_USE_FS 1). When I enter DFU mode, the device pops up but is not recognized on PC, and I am using a Type-C data cable.
hw definition file for processing by chibios_hwdef.py
for H743 bootloader
MCU class and specific type
MCU STM32H7xx STM32H743xx
crystal frequency
#new pll
define STM32_PLL1Q_FOR_USB 1
Required for 48MHz USB clock (from 25MHz crystal)
define STM32_PLL_M 5 # VCO input = 25MHz / 5 = 5MHz
define STM32_PLL_N 192 # VCO output = 5MHz * 192 = 960MHz
define STM32_PLL_Q 20 # USB clock = 960MHz / 20 = 48MHz
board ID. See Tools/AP_Bootloader/board_types.txt
APJ_BOARD_ID AP_HW_NIMBUS
ChibiOS system timer
STM32_ST_USE_TIMER 2
bootloader is installed at zero offset
FLASH_RESERVE_START_KB 0
FLASH_BOOTLOADER_LOAD_KB 128
FLASH_SIZE_KB 2048
order of UARTs (and USB)
SERIAL_ORDER OTG1 USART2
USB
PB14 OTG_HS_DM OTG1
PB15 OTG_HS_DP OTG1
If board provides no VBUS sense pin, disable sensing and force USB connect
HAL_USB_FORCE 1
CONFIG_BOARD_USB_VBUS_SENSE_DISABLED 1
pins for SWD debugging
PA13 JTMS-SWDIO SWD
PA14 JTCK-SWCLK SWD
UART7 is debug
PE7 UART7_RX UART7 NODMA
PE8 UART7_TX UART7 NODMA
telem1
PD5 USART2_TX USART2
PA3 USART2_RX USART2
start peripheral power on
PB2 VDD_5V_PERIPH_EN OUTPUT HIGH
PI15 VDD_5V_RC_EN OUTPUT HIGH
PJ0 VDD_3V3_SD_CARD_EN OUTPUT HIGH
PJ2 VDD_3V3_SENSORS_EN OUTPUT HIGH
PI13 VDD_GPS_TELEM_EN OUTPUT HIGH
enable DFU by default
ENABLE_DFU_BOOT 1
support flashing from SD card:
power enable pins
Enable FATFS in bootloader
define HAL_OS_FATFS_IO 1
#define AP_BOOTLOADER_FLASH_FROM_SD_ENABLED 1
microSD support
PC12 SDMMC1_CK SDMMC1
PD2 SDMMC1_CMD SDMMC1
PC8 SDMMC1_D0 SDMMC1
PC9 SDMMC1_D1 SDMMC1
PC10 SDMMC1_D2 SDMMC1
PC11 SDMMC1_D3 SDMMC1
#define FATFS_HAL_DEVICE SDCD1
Add CS pins to ensure they are high in bootloader
PE3 BMIO88_G_CS CS
PE4 BMI088_A_CS CS
PJ14 BMI270_CS CS
PJ15 DPS310_CS CS
PI5 MS5611_CS CS
PC0 FRAM_CS CS SPEED_VERYLOW
PK1 EXT1_CS1 CS
PK2 EXT1_CS2 CS
Even i am facing the same issue is the issue solved ??
