This is a Quad, has had many auto tune sessions, this vibration is new. In the logs are three separate short flights, one of which the drone shot up before I could get it under control.
Not sure where you started from before running Auto Tune but it did not give you PID’s in the ballpark for this craft. Thrust to weight is high but the PID values are all low with a result like this:
Start over with the Tuning Blog. Suggest Throttle referenced Notch and disable FFT.
On any craft if these parameters Auto Tune lower than default you can typically be assured of a bad tune:
ATC_ANG_PIT_P,4.356567
ATC_ANG_RLL_P,3.580719
I had to change out the ESCs but I was not sure that doing so would cause a re-tune. I very much appreciate your help! I’ll have to have a good stiff drink before I do the auto tune crap again Tuning is difficult for me.
