There is a code we are running which switches between guided and auto mission.
I runned this code for few times and it worked perfectly.
But today drone ascended unintentionally with EKF warning messages.
Here is the log: https://we.tl/t-qVMz680cAz
Thanks for the reply.
I added vibration dumpers under the corners of Pixhawk 4. For the GPS Glitches what we should do? We have another GPS(RadioLink TS100) which we can use beside of Pixhawk 4’s external GPS. Would it be better?
Advice about what? In general you have some odd PID values with Pitch at default and Roll very different. You have missed some of the Initial Tuning parameters. Use Mission Planners Alt>A tuning plug-in to correct that. You should also configure the Dynamic Notch Filter.
