Greetings, friends. I’ve been reading discussions on this forum for a week, and it seems I’ve done everything I could, but I can’t solve the problem. I’m hoping for your help.
In the following code, I change the flight mode to GUIDED_NOGPS (successfully), arm the drone (successfully), and try to set the home point (unsuccessfully). I tried to execute the take_off command without a home point, but the command also fails to execute.
The drone is equipped with optical flow and a rangefinder. The settings, it seems, are correct.
master = mavutil.mavlink_connection(connection_string)
master.wait_heartbeat()
print("Going to GUIDED_NOGPS")
master.mav.command_long_send(
master.target_system,
master.target_component,
mavutil.mavlink.MAV_CMD_DO_SET_MODE,
0, # confirmation
1, # CUSTOM_MODE_ENABLED=1
20, # mode. FLOWHOLD=22; GUIDED_NOGPS=20
0, 0, 0, 0, 0 # (not used)
while True:
ack_msg = master.recv_match(type='COMMAND_ACK', blocking=True, timeout=1)
print(ack_msg)
if ack_msg is not None:
if ack_msg.command == 176 and ack_msg.result == 0: break
time.sleep(1)
time.sleep(2)
print("Checking flight mode")
status_msg = master.recv_match(type='HEARTBEAT', blocking=True, timeout=5)
if status_msg is not None:
flight_mode = master.flightmode
print(f"Mode: {flight_mode}")
time.sleep(2)
Print:
COMMAND_ACK {command : 176, result : 0, progress : 0, result_param2 : 0, target_system : 255, target_component : 0}
Mode: GUIDED_NOGPS
Next:
print("Going to arm")
mavutil.mavlink.MAV_CMD_COMPONENT_ARM_DISARM,
0, # confirmation
1, # param1 (1 to arm, 0 to disarm)
0, 0, 0, 0, 0, 0 # params 2-7 (not used)
while True:
ack_msg = master.recv_match(type='COMMAND_ACK', blocking=True)
print(ack_msg)
if ack_msg.command == 400 and ack_msg.result == 0: break
print("ARM. Command=", ack_msg.command, "; result=", ack_msg.result)
time.sleep(0.5)
print("Going to set home point")
mavutil.mavlink.MAV_CMD_DO_SET_HOME,
0, 0, 0, 0, 0,
55.135,
61.155,
190 # height above sea m
time.sleep(5)
while True:
print(ack_msg)
print("Set home. Command=", ack_msg.command, "; result=", ack_msg.result)
break
time.sleep(0.5)
time.sleep(5)
print("Going to Fly")
mavutil.mavlink.MAV_CMD_NAV_TAKEOFF,
0, # Pitch Angle
0, 0, 0, 0, 0, 0,
1 # Alt
while True:
print(ack_msg)
if ack_msg.command == 22 and ack_msg.result == 0: break
print("Take off. Command=", ack_msg.command, "; result=", ack_msg.result)
time.sleep(0.5)
Print:
Going to arm
COMMAND_ACK {command : 400, result : 0, progress : 0, result_param2 : 0, target_system : 255, target_component : 0}
COMMAND_ACK {command : 179, result : 4, progress : 0, result_param2 : 0, target_system : 255, target_component : 0}
Set home. Command= 179 ; result= 4
Going to Fly
COMMAND_ACK {command : 22, result : 4, progress : 0, result_param2 : 0, target_system : 255, target_component : 0}
Take off. Command= 22 ; result= 4
if I change mode to GUIDED so I unable to ARM and the same problem with home point:
ARM. Command= 400 ; result= 4
Log:
There are no ERR messages in the log.
Flight controller: CUAV Nora+
Computer: Raspberry
Firmware 4.4.4
No GPS installed
