I read a lot of criticism about the ODIN module on the C099-F9P card. It is said to be complicated and complicated to use. I wondered why someone as ingenious as the creators of ZED F9P would sell us such a difficult-to-use C099-F9P device. There is no need to upgrade Mbed, it is enough as it is. It’s ingeniously connected, compact and easy to use !!!
1st part
-According to the Ublox video about 16 min https://www.youtube.com/watch?v=5MXh63XDfdY set one card as Bluetoth Rover using Terraterm,
-The phone’s wifi remains free for later connection of the phone to the Internet.
-Pair with a mobile phone using bluetoth
-Run Ntrip Client on your mobile phone
Part 2
-connect USB second cards - Base to PC
-Start U-center. In the U-center, start the NTRIP server.
-Use the bluetoth mobile phone connected to Rover to connect to its own NTRIP server running in U.center. You have a free wifi interface, it can be used to connect to the internet.
You can also connect the Base to a PC using Wifi Odin. then there is no need for a cable between the PC and the Base.
If you are on the same subnet everything is ok. If you are outside the subnet, it is necessary to set up a router to redirect you from the external Internet to the internal IP computer running the U-center with the server.
No need for a complex public Ntrip server.
No need to reinstall ODIN.
It’s so ingeniously simple and compact ZedF9P + Odin
forms a great whole.
I apologize for the machine translation into English.
Thanks
Jirka
