I can confirm that it does not display heading and speed of the ADSB-enabled craft, but it should display the altitude ASL in meters (not labeled with units) at the end of the text field when you hover over them. See the selected aircraft in the image below:
Thanks for your answer. So it seems I’m doing nothing wrong. Actually, altitude is already the most important information to know. But it’s only shown if I mouse over the plane.
Maybe this is something that could be implemented in mission planner? Just showing the airplanes without any information isn’t very useful…
I agree wholeheartedly - I have particular difficulty with it, as I often use a rugged laptop with a tiny touchpad: that makes it difficult to mouse over as the plane is “running away”.
The design decision may have to do with cluttering of the UI, or that there were performance concerns with additional continually displayed floating text.
This would make a good feature request issue on the GitHub.
Edit: I was going to recommend calling out Michael Oborne, but it seems you’ve already done so.
