I have 2 GPS connected to 2 UART port in my Flight controller. Is there any hardware available for converting these 2 GPS to a CAN device so that I can connect it to the CAN port?
The reason to connect is because the UART ports are limited and I want to use these ports for some other purpose.
Really looking for your response and help in this. Thanks!
Hi @Yuri_Rage,
Just want to confirm that: I can connect 2 GPS to UART1 and UART3 port in this CAN node right?
And one more thing, I am using Pi zero 2W onboard my drone and I have connected it to the FC, I want to record the logs in raspi. Is there any script or something already available which I should see?
Just one more thing I want to add, I have a camera which outputs USB video and I want to convert it to the analog video. Do you know any converter or any way which I should try?
