Has anyone also faced the same issue under Loiter GPS or Loiter Optical flow?
Can the Loiter flight mode be tuned so that the UA does not return to the start position after the pilot releases the stick to the middle?
If the Loiter parameters are okay, what is the cause then?
Play with the loiter tuning and loiter break parameters until it does. But there will Always be a delay due to inertia, so it will never stop at the exact location where you released the stick unless you change the source code or add a lua script.
keeping PSC_POSXY_P, and PSC_VELXY_P to the default, I notice the return to start position after stick release is more obvious when users reduce the LOIT_SPEED below 250.
I have tried giving LOIT_BRK_ACCEL,300 (max 250) a try, no significant improvement.
