Barsuk
(Gleb Dolgov)
January 1, 2024, 10:59pm
1
I’m using a taranis qx7 with the TXMOD V2, and a RFD900x radio connected to an F405 wing. I turn on the 900x, then the TXMOD, connect to the txmod with wifi on my phone, change some settings like the air speed, save params, and upon powercycling both radios the settings reset. No idea what to do here.
Barsuk
(Gleb Dolgov)
January 10, 2024, 5:02am
2
The problem persists with a TX-16s. I think it could possibly be a firmware issue.
xfacta
(Shawn)
January 10, 2024, 5:39am
3
Do you make the changes via the web interface of the TXMOD?
Check this process:
I’m adding a “How-To” for the TXMOD and SBUS for RC control.
I’m covering two aspects here:
SBUS
Increasing the baud rate - partially because that’s how I have mine set, so better to mention it now than have anyone confused by the screenshots, and partially because nearly everyone should update to the higher baud rates unless you fly very long distances
On the air-side/remote radio you need the SBUS output connected to the RCin of your flight controller. It’s the same pin as for RC/PPM but t…
I suppose the next step is reloading the TXMOD firmwares? There are two bits to it…
Otherwise email support@rfdesign.com.au
