Hello friends. Is it possible to set up Ardupilot thus my motor change direction with a switch?
What I mean is:
I push the throttle up - my boat goes forward
I push it down - the boat stops
I move some aux switch down (let’s say channel 10)
I push the throttle up - my boat goes backward
and so on.
I know that there are ESC exists with aux channel. Can I do it without it?
Ardurover works best with bidirectional ESCs and a spring loaded (self centering) throttle stick.
If your ESC does not support bidirectional operation, there is no way to make the motor turn backwards via any setting in the autopilot.
Achiving the operation you discribed with a bidirectional ESC would be possible with a mixer in the TX or a lua script, perhaps.
this is easiest done on your transmitter if it supports custom mixing, most opentx and other modern radios should be able to do this without much issue. essentially its just a selectable throttle range. so default position gives you 1500-2000 for forward only and when you flip the switch it changes that range to 1500-1000 for reverse.
trying to do it with your motor controllers is just going to cause problems with how ardurover controls it.
unless your trying to physically move a throttle control on an engine?
I set up my ESC for reverse function, thus it works like this: throttle value = 1500 neutral, 1500 → 2000 forwrard direction, 1500 ->1000 backward direction.
I mix throttle with a switch in transmitter, thus I can control direction with this switch
I see two problems with this solution
Switch changes motor direction at any time I switch it, even at full speed. Won’t it kill the motor if it chages rotation dierction at full speed?
If I start a mission at low speed, the boat goes backwards at high speed.
Right. Logic to not allow it to switch unless the throttle is at neutral is a good idea. Logical switches in OpenTx will do this, not sure about other platforms.
I don’t understand point 2.
If this scheme doesn’t sound right to you why bother with it and just use a spring center throttle as suggested? It’s the most common method.
I feel so stupid. I am trying to get a rover to do a grid. It goes to the waypoints, runs a huge wide turn. I tried the skid-steer mod that sets servo1 to 73 and servo 3 to 74, and now it just describes huge circles, ignoring the planned waypoints. I’m doing something totally stupid. I put the do_set_reverse in and it didn’t reverse. Again, I’m being stupid.
You have to set the rover-skid option in the sim window PRIOR to starting the simulation.
Since you’ve probably mucked about with other stuff at this point, also check the “wipe” option to undo any other mistakes before running the sim.
You are posting a mile a minute and asking the same questions multiple times. Maybe start a dedicated topic for your project and keep discussion corralled to that?
