just use those for fixed mount - those rubber posts work very well.
https://www.amazon.com/uxcell-Thread-Vibration-Isolators-Absorber/dp/B07KT3QRX5/ref=sr_1_1?keywords=5mm%2Brubber%2Bmounts%2Bm4&qid=1573566475&sr=8-1&th=1
Thank you very much Paul Atkin,
I have a custom frame with little space and I can’t use that mount.
those mounts exist in different form factors, including M3 as well, you just need to search for one that fits. there is no other good solution to mount small FC, really.
this one below is the same rubber post in M4 8mm height. works fine in a standard 20mm stack format with ESC below.
I’ve used M3 of these but found them a little too solid, I currently have some customized lumiere silicon mounts (https://www.getfpv.com/orange-rc-bobbins.html) but its not ideal. It’s one reason I wrote the harmonic notch as vibration isolation on these small copters is just too hard
true, very true. now with this great new filter the firmer ones actually should be benefitial for racing models, as you ideally want FC to wobble the least amount possible in sharp turns, while still isolating from motor noise. so it is always a difficult task, i also used similar ones, and sometimes in a combination of 2 softer ones and 2 firmer ones. still, it is a same approach, to use a rubber bobbin in a usual mounting hole. in the gecko i actually used both the combination of those bobbins and the rubber insert into the hole the kakute f7 mini came with. seems to be ok.
Like I mentioned in the microarducopter thread, I still use tape for my FC… Like the old original pixhawk, heh… Usually little gel pads and very strong double sided tape. Can make them thin, so the FC is just barely above the ESC. The FC’s are so light I’ve never had the tape come loose, and I fly daily for years now on these copters.
Although like Paul mentioned, hard mounting might be better now with the filter… I think I’ll try hard mounting this winters project.
double side foam tape works in some scenarios, as long as you do not tape to the surface of the ARM processor chip as in this case it may overheat.
i used to do that, but, i also found that after some series of good smacks FC sometimes comes off that tape, well, if you hit frame hard enough at a tree or something - those armattans can survive pretty much anything… rubber posts have never failed me yet.
Full sponge on the barometer and INS_HNTCH_BW = 50. A battery without rocket and starts the autotunning on the roll axis
In alt hold (with 1 meter security cable), it sometimes loses altitude and I have to give it gas. Maybe because it’s too low?
Can it be useful to set these parameters? specially MOT_THST_EXPO?
- MOT_BAT_VOLT_MAX - 4.2v x No. Cells
- MOT_BAT_VOLT_MIN - 3.3v x No. Cells
- MOT_THST_EXPO - 0.55 for 5 inch props
These won’t affect AltHold much.
MOT_THST_EXPO is important to get right as it linearizes your thrust - which means that the tune you get at hover still works at full throttle.
I think you should look more at the PS_ACCZ_* settings
Foam looks much better!
OK PS_ACCZ_* settings, next step!
I have this now:
PSC_ACCZ_D,0
PSC_ACCZ_FF,0
PSC_ACCZ_FLTD,0
PSC_ACCZ_FLTE,20
PSC_ACCZ_FLTT,0
PSC_ACCZ_I,0.28
PSC_ACCZ_IMAX,800
PSC_ACCZ_P,0.14
I will try with : PSC_ACCZ_FLTD,40
Mine are:
PSC_ACC_XY_FILT,2
PSC_ACCZ_D,0
PSC_ACCZ_FF,0
PSC_ACCZ_FLTD,40
PSC_ACCZ_FLTE,20
PSC_ACCZ_FLTT,0
PSC_ACCZ_I,0.37
PSC_ACCZ_IMAX,800
PSC_ACCZ_P,0.185
I have a feeling those are not quite correct either though.
Not all these parameters are transferable from one copter to another, especially
PSC_ACCZ_I and PSC_ACCZ_P that must be PSC_ACCZ_I = 2 x MOT_THST_HOVER and PSC_ACCZ_P = MOT_THST_HOVER with MOT_THST_HOVER the hover learned.
One interesting thing that I see on @andyp1per params is PSC_ACCZ_FLTD=40, when you pass from 3.6.11 to 4.0.0 this param is set to 0, I have to try with 40.
I noticed the same thing, I’ll try as soon as possible
Yeah I have a feeling that @Leonardthall wanted to change this. Note that my AltHold is absolutely rock solid with my current settings …
Have you changed in some way also PSC_POSZ_P and PSC_VELZ_P ?
PSC_POSZ_P,0.3
PSC_VELZ_P,4
Not sure where I got these from
Hi Andy
any idea if the dynamic filter will work if running dshot with telemetry via canbus?
i’m thinking of trying to build some of olliew’s UC4H ESC-Actuator
It will only work with BLHeli telemetry at the moment, and I think that;s limited to serial port access.
When using the dynamic notch filter will I also see a reduction in the log analysis „vibration 3.3“ in Mission Planner?
BR
Harald
I would say yes, but I think that measures the accels which is a second order effect.
