Hi.
For a couple of weeks, I have been trying to tune my heavy quadcopter.
It is equipped with KDE7208XF-135 motors, KDE 24.5 inch dual propellers, and KDE-UAS75HVC ESCs.
The takeoff weight of the quadcopter is nearly 13kg.
Lots of PID tuning wiki reads and tuning flights, I have accomplished reasonable stable flights on both manual and auto modes.
I am attaching the logs.
However, I can not be able to reduce vibrations.
Vibrations on the X and Y-axis seems to be reasonable and do not interfere with stable flight.
I am seeing peak to peak 2 meters of altitude error on auto flight modes.
I am thinking that it is related to high vibration in Z-axis.
Is this Z-axis vibration normal since it is a really big drone or should I focus to reduce them?
If so, how can I achieve that?
I did some fixing on wires and other things inside the fuselage and nothing seems that it can be moved during flight.
Can I improve Z-axis vibration and better altitude controlling?
Is it related to PSC_VELZ_P?
Thanks for all of your efforts and suggestions.
https://drive.google.com/drive/folders/1BwohvNEUg5LWb8VEvcYmYc-GQ7LBCliY?usp=sharing
Hi @Mustafa_Gokce
your tune is not too bad
but these PIDs are high for a 24inch copter
vibration on z is a bit high and could make altitude and vibration problem
you can setup harmonic notch filtering to reduce noise on gyro
after this send us a log with LOG_BITMASK = 196607 for a better analysis
good luck with tuning
how do you measure your 2 meters hight error, thats within gps and baro error
How is that Cube mounted? As Hosein says the dynamic notch filter would likely help. Set INS_LOG_BAT_MASK to 1 and make a simple AltHold Hover flight for ~1 minute and post that log.
Hello again @hosein_gh and @dkemxr
Sorry for the late response to your suggestions.
Today I had a chance to do your suggestions regarding logging parameter settings (except notch filtering).
Could you please look at the log files below in your free time?
https://drive.google.com/drive/folders/1YWUNBF3TXlufFgtqnyoGbWURQ2PQKK81?usp=sharing
Thanks for all of your efforts…
My sincere regards…
OK you have high amount of noise on 100hz
set these parameters
- INS_HNTCH_ENABLE = 1
- INS_HNTCH_REF = 0.4437652
- INS_HNTCH_FREQ = 100
- INS_HNTCH_BW = 50
- INS_LOG_BAT_OPT = 2
then do a 1min hover flight in althold or loiter and send log file again
Dear @hosein_gh.
Thank you for the suggestions…
I set the parameters according to your suggestions.
I attached the logs.
https://drive.google.com/drive/folders/1Fw3tCLQDhHWo10ozODTPBE83oiL23sH-?usp=sharing
Could you please look at them?
Thanks
no FFT data in this log
did you uploaded correct log file ?
also did you set INS_HNTCH_MODE = 1 ?
@hosein_gh, yes I can’t see it either.
Yes thats the correct log file.
I didn’t change any log parameter except INS_LOG_BAT_OPT.
I checked INS_HNTCH_MODE,1.
Should I do a flight again?
Thanks.
yes we need another hover flight with these settings
INS_LOG_BAT_MASK = 1
LOG_BITMASK‘s IMU_RAW bit must not be checked. The default value is fine
INS_HNTCH_MODE = 1
INS_HNTCH_BW = 50
INS_LOG_BAT_OPT = 2
I will do the flight in a couple of hours and will send the logs to you.
Thank you so much for your interest and kind answers.
My best wishes…
Hi, again @hosein_gh.
Sorry for the long waiting.
There was a strong wind yesterday so we canceled the flight.
Today we did 2 flights (on separate drones but the drones are identical).
https://drive.google.com/drive/folders/1n8wwqk8NtewZ5wnz_PwtpsurumY1q9JQ?usp=sharing
OK now you have much less noise (its reduced from 700 and 150 to 18 and 12)
and its affected your pids
so go ahead and do another autotune again to get right PIDs
but before running autotune you need to fix your motors unbalance
CW motor are working harder, is CW arms/motors twisted ?
but a note motor unbalance happened in you second flight
in fist flight it was ok
first try to recalibrate ESCs
@hosein_gh, in these flights, did the notch filter really affected the PIDs?
I might be wrong but could the filter affect only the logged IMU data?
Because there are two parameters related to harmonic notch filter.
Those are INS_HNTCH_ENABLE and INS_NOTCH_ENABLE.
During these flights the parameter INS_HNTCH_ENABLE=1 but INS_NOTCH_ENABLE=0.
Should I change INS_NOTCH_ENABLE to 1?
I will take a closer look at the drone that corresponds to the second log.
The drone’s ESCs might be incorrectly calibrated since the arms and motor mounts on the drones are really strong and stiff.
I will do the AUTOTUNE as you suggested and post the logs.
Also, I wanted to mention that on the second flight (corresponds to the second log) I saw some small instabilities (like really small oscillations) during pitch backward. I didn’t see those oscillations during pitch forward and roll maneuvers. If I am correctly remembering, I did this 3 times and saw these oscillations only when pitch backward. There wasn’t anything like that on the first flight.
Thank you for all of the suggestions
because of reducing noise on output FC will have different calculation
No its for static notch
its because of your PIDs, don’t worry it will be fixed after autotune
Good luck with tuning and let us to know how you go
This is for the fixed notch filter so no. Unless you want a fixed notch but all discussion to date has been for the Dynamic Notch.
Also, you should set the INS HNTCH_ATT to 40 and make another Hover flight.
Dave is right at the first look i think it was INS_HNTCH_ENABLE
Sorry for mistake
I edited the last post
Thank you for the suggestion.
I will do it on Monday and will send the logs immediately.
Best wishes…
You may get a message in Mission planner saying 40 is out of range for this parameter. Ignore that and make the change.
Hello again, @dkemxr and @hosein_gh.
Today i attempted to do the autotune process with INS HNTCH_ATT=40.
There was a strong wind but i was able to finish tuning processes on roll and pitch axes.
I am wondering about whether it worked or not since there was wind during the process and i had to intervene the process most of the time because of the drift.
Thanks for all of your efforts.
Regards…
https://drive.google.com/drive/folders/1wpCSBrzkSg5Amj_RqLVwCqzDZUxQLy7F?usp=sharing
