I am about to go out for my second flight, which hopefully wont end in a crash since i replaced an esc!
I have an APM 2.6 and a 6 channel remote. To start with, since I suck at flying, I think I would like to manually do some trimming.
I have read the page of the wiki on this so these questions are in addition to the content there.
Is there a way for me to use Save Trim on Channel 6 instead of 7? My receiver is communicating with ppm so i cant switch channel wires around. If I do use save trim, do i have to set the transmitter trims back to 0 after I believe it has saved?
For Adv Params in Mission Planner, could someone give me a sense of what values are appropriate and/or what a reasonable step up and down would be? Is it literally if I think the thing is leaning 4 degrees to right right i convert that to rads and then change the value by that much?
Any other good beginner advice not in the wiki?
thanks!
