Yes, for a simple solution you can execute a simple python script on Rpi, which will be continuously listening for a signal from pixhawk (signal responsible for triggering camera ). after detecting the signal you can trigger the cam.
Example:
import RPi.GPIO as GPIO
import os, sys
import time
import argparse
# Init GPIO, use GPIO pin 5 as input trigger from APM/Pixhawk
camTrigger = 5
GPIO.setmode(GPIO.BCM) # specify which mode to use(BCM/BOard) for pin numbering
GPIO.setwarnings(False) # It is possible that you have more than one script/circuit on the GPIO of your Raspberry Pi. As a result of this,
# if RPi.GPIO detects that a pin has been configured to something other than the default (input), you get a warning when you try to configure a script. To disable these warnings:
GPIO.setup(camTrigger, GPIO.IN, GPIO.PUD_UP) # You need to set up every channel you are using as an input or an output. To configure a channel as an input:GPIO.setup(channel, GPIO.IN)
# pull_up (bool or None) – If True (the default), the GPIO pin will be pulled high by default. In this case, connect the other side of the button to ground. If False, the GPIO pin will be pulled low by default. In this case, connect the other side of the button to 3V3. If None, the pin will be floating
def SendCmd(shutter):
os.system(f'cmd /c {shutter}') #Command Prompt will be closed following the execution of the commands.the command will still get executed, but you may not be able to see it on your monitor.
shutter = "libcamera-still -t 10000 --autofocus -0 newimage.jpg"
def capture():
while True:
if GPIO.input(camTrigger) == True: # reading input (high/low)
print("Shutter Triggered")
SendCmd(shutter)
# Wait for it to go False
while GPIO.input(camTrigger) == True:
time.sleep(0.1)
print("Shutter Off")
capture()
GPIO.cleanup()
https://ardupilot.org/copter/docs/common-pixhawk-camera-trigger-setup.html
You can use above link to configure pixhwak aux pin for cam trigger signal.
I hope it helps.
