Tree foilage covering map area for lawnmower path planning
Hi Yuri,
Thankyou, thats the answer I needed. My appologies again for the seemingly troubling questions.
Regarding the Lua Script.
  1. Is it strictly for Perimeter Mapping or can it be used for mapping entire pathways manually toggling/marking waypoint at each turn in Mission Planner? The reason I ask this question is the comment made below gave me the impression it was strictly perimeter only.
“You can use this Lua script to trace a perimeter by driving in manual/acro/steering mode while the script is active.”
  1. When Mapping Pathways is it possible to go to a Waypoint and add plus 3 Meters then right turn 45°? Or is Mission Planner strictly GPS Based only? I ask this question as I have built commercial Rovers for inside environments prior to the existence of GPS.
  2. Is pathway mapping in Mission Planner all done with Polygones only?
Thankyou again
