Transition to Ardupilot and Drone Automation
Hello everyone,
I am a university student currently working on my bachelor’s thesis, which involves building a space surveillance drone using Arduino-based components. However, I am facing some challenges and have a few additional questions about my project.
Project Overview:
Here is the hardware I am using for the quadcopter:
  • Flight Controller & ESC: Speedybee F405 V4 stack
  • GPS Module: u-blox 7M
  • Receiver: FlySky FS-A8S
  • Camera: ESP32-CAM module
I have successfully flown the drone using the controller, so basic functionality is in place.
Current Software Setup:
I initially set up the flight controller with iNav to explore its features. However, since my project requires autonomous flight and more advanced functionalities, I decided to switch to Ardupilot.
Problem:
When I try to connect the flight controller to Mission Planner, I encounter the following issue:
  • After clicking the “Connect” button, I receive the error message: “No heartbeat packets received” after 30 seconds.
I suspect the issue might be related to flight controller drivers, but I’m unsure how to update or troubleshoot them effectively.
Questions:
  1. In the final version of the project, I want the drone to start its flight and initiate video recording when it receives a signal (e.g., an alarm signal or a similar remote trigger).
  • How can I configure the drone to accept such a signal to initiate flight?
  • Should this be managed through the flight controller or the ESP32-CAM module?
  1. I also need the ESP32-CAM module to begin recording automatically when the flight starts.
  • How can I program the ESP32-CAM to synchronize video recording with the flight start?
I would greatly appreciate any guidance, advice, or resources you could share to help me resolve these issues and advance my project.
Thank you in advance for your time and support!
you will need to flash the ardupilot firmware to the flight controller first before you can use it.
https://ardupilot.org/copter/docs/common-loading-firmware-onto-chibios-only-boards.html
for esp32 cam you I believe you can program a pin to start and stop recording, then you can use the relay pin output from ardupilot connected to an esp32 pin to replace a button to enable you to start and stop the recording from your transmitter.
https://ardupilot.org/copter/docs/common-relay.html
