Nice conversion, Graham!
Yesterday we did the first complete forward tiltrotor transition. However, the motors do not get any power at the end of the transition. This takes so long until they have reached their final position.
This is problematic, as we need a slow tilt at the beginning of the transmission, so that the aircraft does not lose its height. Would it be possible to have two parameters ie Q_TILT_RATE_1 for the first, Q_TILT_RATE_2 for the second part of the forward transition ? After Transition, in FBWA mode, the behavior was great with default values. Unfortunately, instead of the reverse transition, we chose a cherry tree landing. Fortunately, not much damage has been made, and on the next flight, we will also carry out the reverse transition.
Rolf
@Rolf, congratulations on the full transition flight!
Can you upload the DF log of this flight for me to take a look at?
Thanks!
@GregCovey, many months ago (in a galaxy far, far away?), I promised to do some more work on the CL84. You may have died of old age waiting, but Iāve finally done it.
What Iāve done is:
- updated support for binary tilt rotor quadplanes to current master
- found and fixed the cause of the āmotor poppingā
- built up my own CL84 (finally!) so I am ready to fly it in in the next few days
Iāve put a new build for Pixhawk here:
http://uav.tridgell.net/CL84/ArduPlane-v2-CL84-test3.px4
it works fine in bench tests for me, and also works fine in the simulator. I havenāt actually flown it yet though.
Note that on my CL84 I measure the time taken for the wing to tilt as 7 seconds, whereas I believe you measured a much shorter time. I can only think that perhaps our servos are a bit different?
If you want to try the above binary then be aware that a lot of the parameter structure has changed over the last few months, so check your parameters carefully. In particular, check that: - Q_FRAME_CLASS=7
- Q_FRAME_TYPE=1
- Q_TILT_TYPE=1
Iāll let you know when Iāve tried a flight
we certainly could add that, Iād like to look at your log first if you donāt mind though. There should be throttle output while the tilt servo is moving, and Iād like to understand why you donāt see any.
Iāve also opened a pull request for the Q_TILT_TYPE support (which is needed for CL84):
once it has had a test flight Iāve remove the WIP label and we can get it into master
answering some old msgs from this thread:
when you switch to MANUAL mode in a quadplane you immediately lose all multicopter stability. There is a warning about this in the documentation, but I can understand why it can be confusing.
If you switch to FBWA mode then you donāt get this problem, and it should keep providing multicopter stability until it has completed the transition. With the fixes I just put in this transition completion will be at a fixed time for the CL84 if you have Q_TILT_TYPE=1, which tells ArduPilot that it is a retract type servo, and thus you canāt control the tilt rate.
Will try to upload the logfile this evening (UTC), but its 750 MB (2 minutes flighttime, more then 2 hours hanging in the tree. It took us several hours to recover the plane)
Regards Rolf
@Rolf, make sure up upload the .bin file, not the .log, and compress it (with zip or similar).
You could also pull out just the first few minutes of it - just truncate the file at 5% or so
@tridge , the truncated bin file. 88truncated.zip (4.2 MB)
@Rolf, thanks for the log, that helps a lot!
@Rolf,
The reason the throttle on the forward motors went to close to zero during the last part of the transition was that the aircraft was gaining height. Until the rotors have tilted all the way forward the multicopter controller is still in control of the rotors. The controller is being asked to maintain height - it is essentially in QHOVER mode as far as the multicopter controller is concerned. The vehicle was gaining height, so it lowered the throttle to try to stop climbing.
Cheers, Tridge
Hi Trdge, thanks for the fast respond. I have very well pulled on the elevator-stick, because the aircraft lost height ?
Regards Rolf
hmm, youāre right, sorry, Iāll look again!
@Rolf, ok, got it this time, and it is a bug.
The vertical throttle in the ātimer waitā part of the transition (when waiting for Q_TRANSITION_MS to timeout after reaching target airspeed) uses a stabilize throttle, not a hover throttle. It slowly lowers the throttle starting at the throttle it was using at the point it reached the target airspeed:
See:
https://github.com/ArduPilot/ardupilot/blob/master/ArduPlane/quadplane.cpp#L1057
In my pending tiltrotor PR I have changed it so it never lowers target throttle to zero while in the transition wait:
https://github.com/tridge/ardupilot/blob/pr-plane-binary-tilt/ArduPlane/quadplane.cpp#L1068
so it will keep stabilizing. As the fwd rotors are tilted forward, they will get a larger amount of thrust for pitch stability, so you will get more forward throttle in this stage of the transition.
Thanks for noticing this, and thanks also for not accepting my bogus initial answer!
Cheers, Tridge
thanks for looking again and fixing the bug. Important to know: Q-TRANSITION_MS ist starting after reaching target airspeed. Until we have the possibility to install a compiled version, we will try changing Q_TRANSITION_MS from 5000 to minimal ie 10,
Iāve put a new build here:
http://uav.tridgell.net/CL84/ArduPlane-v2-CL84-test4.px4
Success!!
Iāve flown the CL84 tiltwing with ArduPilot and it flew very nicely. Did several manual flights with transition, then did 3 full auto flights (auto VTOL takeoff, auto-transition, auto-mission and auto VTOL land).
Unfortunately on the last auto-land one of the front propellers came off. Turns out the left/right props were mislabelled from the factory, so the nuts were self-loosening instead of self-tightening. It crashed hard when it lost the prop while hovering, but looks to be repairable.
Iāll post some videos later today.
Cheers, Tridge
@tridge: Congratulations and thanks very much. As soon as our aircraft is repaired, we will test the tiltrotor.
Here is a video of the flying today:
Iāll upload logs and parameters soon.
Note that I flew with a 5.2Ah 4S battery, which is much larger than the recommended 2.6Ah. It is a 10C multistar though, so lighter than a normal 5Ah
