Hi. I’m currently building a tilt copter. Is it possible to add a servo to the quad copter setup on an omnibus f4 or f7 pwm 5 or 6 ?
The Matek F405 has 6 outputs, that should do it. I don’t see a firmware target for the OmniNXT F7. Kakute F7 also has 6 outputs and is supported.
I can’t get servo’s moving on Matek F405 when I select RC-funktion " RC passthrough". Does pwm 5+6 support servo signals or just motors ?
I don’t have one of these boards but a suggestion. What is your BRD_PWM_COUNT parameter set to? Or instead of “RCPassThru” try “RCINx” for the channel you are controlling from.
Pwm_count is set to 6
Odd because the hwdef file for the Matek F405 (F405-OSD) show as follows:
# 8 PWM available by default
define BOARD_PWM_COUNT_DEFAULT 8
Omnibus F4 default is 6
is PWM5+6 supporting servo output ?
