merhaba drone u kullanırken thrust loss(1) hatası aldık daha sonra esc lerimizi değiştirdik. Pervaneleri değiştirmeden arm verdik ve thrust loss(4) hatası aldık yardım olur musunuz? isterseniz log kayıtlarımızı atabiliriz.
Post a link to the .bin log file.
This craft is barely flying. It’s underpowered/overweight and there is a mechanical yaw bias.
Here you can see the CCW motors commanded to max. This is the cause of the thrust loss errors, there is insufficient thrust for stability.
esc de sıkıntı olabilir mi
I doubt that. Your battery is sagging badly also.
Describe the components on this craft and it’s take-off weight with battery (motors, esc’s, props).
merhaba, drone ortalama 3.5 kg ancak drone dan sarkan 2 m su alma aparatı bulunmaktadır.
şuan tekrar uçurmayı denedik ve takeoff atadıktan anında potential thrust loss(1) hatası verdi ve drone 30 cm yükselip yere çakıldı. log kaydımıza bakar mısınız?
https://dosya.co/zxzkv1hi5cra/00000150.BIN.html
That isn’t enough information and this log shows the same problem. Under powered/over weight.
Again. Describe the components on this craft and it’s take-off weight with battery (motors, esc’s, props).
motor: sunnysky x3608s-1 700kv
propeller: 11"55
flight controller : pixhawk 2 cube
gps:here 2
battery: leopard power 25c 4s 8000 mah lipo battery
esc: esc multistar 30a 480 hz
jetson nano
webcam
Over weight/under powered with that setup. You would be ~ 77% throttle at hover which is what the logs are indicating. You need to be ~50%. 6S battery power would do it if the components can handle it.
