Throttle limit in AUTO
Hi all,
First post here, I am hoping someone can help me.
Maidened my new build over the weekend, and ran into a slight issue.
I will try my best to give as much data/info as possible, please let me know if something else is needed. I am hoping it is something simple (or something silly I have done on my end).
The build:
  • Volantex Ranger EX with standard motor/prop and servos
  • FC: Matek H743 WING V2
  • FW: ArduPlane V4.2.1
  • ESC: Hobbywing Platinum 40A
  • GPS/Compass: Matek M8Q-CAN
  • Airspeed sensor: Matek ASPD-4525 (connected in CAN with GPS, ARSPD_USE set to 0 as calibration still to be performed)
  • Lidar: Benewake Tfmini plus
  • Receiver: Radiomaster R168
  • Battery: X-power 2200mah 25C
  • Other: RubyFPV system with pizero 2W, picam v2, and Alfa AWUS036ACH
The problem:
In AUTO mode, throttle will not go above ~66.5%. This was evident during take-off, and when switching to auto during flight after a manual take-off.
The result:
Underpowered in flight and unable to take-off/gain altitude in AUTO mode.
Checks and observations during maiden flight test campaign:
THR_MAX is set to 100%
TKOFF_THR_MAX was set to 0% during 1st flight, 100% during second, no changes observed
BATT_WATT_MAX set to 0
MANUAL, AUTOTUNE and FBWA modes allow 100% throttle, this allowed for a good take-off and flight in these respective modes
Checks and observations from LOGS:
I have attached 3 logs which I have had a look at (although I have not yet figured out the problem with my knowledge level). Descriptions and observations below:
LOG1: First flight attempt in AUTO with take-off. Plane would not climb more than ~3-4m above ground. Switched to manual to land
  • The throttle limit at ~66% is clearly visible in AUTO mode.
  • Switching to manual/FBWA immediately allowed full throttle.
  • It looks like the throttle did climb to 100% in AUTO mode, right before I chickened out and switched to MANUAL, it may have been me starting to take throttle up with THROTTLE_NUDGE set to 1.
  • For some or other reason, TECS.sp almost instantly climbs higher than the TECS.spdem. My understanding of this parameter may be wrong, but this seems like a potential issue. That being said, I saw similar behavior on another build I did, that did not limit the throttle.
  • What I should have attempted here is using THROTTLE_NUDGE during AUTO to climb out, although this did not occur to me at the time, so it was not done.
LOG2: Varied some parameters (TKOFF_THR_MAX to 100%, and turned off THROTTLE_NUDGE) and attempted same as LOG1, same result.
  • TECS.sp climbed again, but was lower than TECS.spdem. Throttle still limited.
LOG3: Take-off in AUTOTUNE mode, a few mode switches through flight, most of flight in FBWA.
  • Throttle not limited in FBWA/AUTOTUNE/MANUAL modes. Take-off was easy in these modes at 100% power.
  • When switching to AUTO mode during flight (after take-off), throttle was once again limited.
In all the logs, what seems to be electrical interference is clearly visible in the LIDAR, I am not sure if this is related to the issue.
Link to logs below for both dropbox and google drive, please let me know if its not working:
https://drive.google.com/drive/folders/1eFXJMbEbegeoDgH7AVZXu8Whh4oQdAdw
Let me know if there is anymore info that can help.
Once again, I am hoping it is something small I have missed.
Cheers,
Rowan
Watch my video, hope this can help you. Switch subtitles in the settings to your language. I set up my plane in two flights, but I could do it in first flight if the airspeed sensor works correctly.
On my channel you can see the glider setting in first flight, and also in this flight the FBWA, RTL and AUTO modes are checked https://www.youtube.com/watch?v=sgdi_oY-sCM
I use well-flying aircraft models that have previously flown on Radio Control, they are properly tuned and tested. Once installed the flight controller to an aircraft model, the setup is a simple procedure.
Thanks to the developers for the perfect quality of the software
Did you find the cause or a way to solve it?
I experienced a similar issue today but it also affects FBWA:
