Guys, I’m basically new to this. I am using PixHawk 2.4.8 FC and a 10 CH FlySky FS-ia10 Transmitter and Receiver. After long hours of struggle, I am currently at the ESC calibration stage. The calibration was successful. I got the throttle down, and when I slightly pulled up, the motors would spin. All is fine until this point.
- Now, I am not able to arm the copter. If I arm through the buttons, I am getting a PreArm: Check FS_THR_VALUE. When my throttle is down, the minimum value it goes to is 1000, but my FS _THR Value is 950. I change it to 910, 1100. I am getting the same issue. I even changed the Radio under FailSafe to Disabled, but then I got another error, PreArm: Throttle is too high.
Can anyone please help me here? I can see documentation asking us to set the FS_THR value below the value obtained when TX is on and above the value obtained when TX is off. How do I get the TX off values? I’m really confused.
P.S.: My Radio Transmitter sticks always goes to the normal position, doesn’t hold at the extremes.
