Adrian,
That turn radius is quite important as you need to get the craft going at the speed you intend to do your ‘missions’ at, and do the following:
1 - with all RC trims centred, get the craft going perfectly straight (this is a physical adjustment on your steering link)
2 - do a full 360 turn to port
3 - do a full 360 turn to starboard
Take those trails (I use a small Lowrance EliteTi5" to record my trail) and measure the radius on the EliteTi. Or you can convert them to Google (KML) then measure in Google Earth the diameter of those circles - they should be within a meter of two with port being slightly smaller due to prop torque in the water.
Personally I believe that a day will come where all the bloated code will be removed from Rover, and JUST the code that pertains to a Rover will remain, and THAT is when things will start to work right.
I missed speed_turn_gain and speed_turn_dist in rover 4.0 for my german baitboat …
Wp_overshoot 1m, atc_accel_max and atc_accel_max 0.5 and more has no effect …
Wp_speed 1m / s …
This is difficult!
Hey…
Ich vermisse speed_turn_gain und speed_turn_dist in rover 4.0 für mein german baitboat…
Wp_overshoot 1m , atc_accel_max und atc_accel_max 0,5 und mehr hat keine wirkung…
Wp_speed 1m/s…
