TFLuna I2C ArduCopter Installation Guide
Hello everyone from Turkey. I have prepared a guide for installing multiple TFLuna Lidar (6 Pin = Uart / I2C) sensors over I2C. I hope that will be useful.
Solder / connect pin 4 and 5 for I2C.
TFLuna default address = 0x10 = (Binary = 16)
There is no need to make changes for one TFLuna.
ArduPilot Parameters
RNGFND1_TYPE = 25
RNGFND1_ADDR = 16
RNGFND1_MAX_CM = 300
RNGFND_MIN_CM = 10
To connect more than one TFLuan, you need to change the address of other sensors. Otherwise, there will be conflict.
Connect the TFLuna sensor to Arduino.
Tfluna Arduino
Upload the code below to Arduino.
// This sketch changes the addresss of TF-Luna from 0x10 (Binary= 16) to 0x1E (Binary = 30)
#include <Wire.h>
void setup() {
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(115200); // start serial for output print
Serial.print(“Ready to Send command to TF-Luna\r\n”);
//pinMode(LED_BUILTIN, OUTPUT);//LED
// Change the address
Wire.beginTransmission(0x10);
Wire.write(0x5A);
Wire.write(0x05);
Wire.write(0x0B);
Wire.write(0x1E); // Change this line to change the address. (Hexadecimal , Example: 17 = 0X11, 18= 0X12, …)
Wire.write(0x00);
Wire.endTransmission(0);
delay(100);
// Save the address
Wire.write(0x5A);
Wire.write(0x04);
Wire.write(0x11);
Wire.write(0x6F);
void loop() {
Using this code, change the address of each sensor you add.
Check the address change from serial monitor by loading the code below.
#include <Wire.h>
void setup()
Wire.begin();
Serial.begin(9600);
while (!Serial); // Leonardo: wait for serial monitor
Serial.println("\nI2C Scanner");
void loop()
byte error, address;
int nDevices;
Serial.println(“Scanning…”);
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
  Serial.print("I2C device found at address 0x");
  if (address<16)
    Serial.print("0");
  Serial.print(address,HEX);
  Serial.println("  !");
  nDevices++;
else if (error==4)
  Serial.print("Unknown error at address 0x");
  if (address<16)
    Serial.print("0");
  Serial.println(address,HEX);
if (nDevices == 0)
Serial.println(“No I2C devices found\n”);
else
Serial.println(“done\n”);
delay(5000); // wait 5 seconds for next scan
Sample picture
Activate the sensor.:
RNGFNDX_TYPE = 25 (RNGFND2_TYPE = 25 , RNGFND3_TYPE = 25, RNGFND4_TYPE = 25 …)
Using the parameter, enter the address of the sensors in ArduCopter. Enter the Binary equivalent of each sensor’s address.
RNGFNDX_ADDR : ( RNGFND1_ADDR , RNGFND2_ADDR, RNGFND3_ADDR … Sample: RNGFND2_ADDR = 17, RNGFND3_ADDR = 30 … )
Enter the maximum and minimum values for each sensor as follows
RNGFND2_MAX_CM = 300
RNGFND2_MIN_CM = 10
RNGFND3_MAX_CM = 300
RNGFND3_MIN_CM = 10
RNGFNDX_MAX_CM = 300
RNGFNDX_MIN_CM = 10
That’s the whole process. I tried it, it works fine…
Status = Rangefinder1, Rangefinder2 … Check if the sensor is working in the RangeFinder section. (The picture shows the Sonar Range part. See the RangeFinder section in the same place.)
Upgrade TF-Luna firmware, if required.
I searched all over for an answer to this exact situation. Thank you for the concise explanation!
Perfection.
Sir I stucked in a problem when ever I try to change the orientation of tf luna than sonar stop giving readings when I set it to default ( down facing ) it’s working fine can u pls help me in this actually I want to face it at front (0 )value
