FC: SpeedyBee F405 V3 BLS 60A 30x30 Stack
I have installed ArduPilot and was able to connect with QGroundControl and setup radio, calibrate sensors.
However motor test doesn’t work, none of them spins Motor Setup | QGC Guide (4.3)
The same with MissionPlanner on Windows
How can I fix it or debug?
Log:
[08:55:14.495] Info: ArduCopter V4.5.2 (291be848)
[08:55:14.495] Info: ChibiOS: 6a85082c
[08:55:14.495] Info: speedybeef4v3 002B0031 3133470B 33353636
[08:55:14.495] Info: RCOut: PWM:1-8 NeoP:9
[08:55:14.495] Info: Frame: QUAD/X
[08:55:35.659] Info: starting motor test
[08:55:37.181] Info: finished motor test
dkemxr
(Dave)
June 29, 2024, 3:15pm
2
Post a link to the log file.
Janno
(Jan Ole Noack)
June 29, 2024, 4:48pm
3
How did you connect mission planner to the FC? Bluetooth or USB? If USB, did you connect the battery to the ESCs? Did the ESCs beep? Did you calibrate the ESCs before the test?
When you are using BLS, why are you using PWM anyway? You should use DShot for BLS. You should also use the -bdshot target for the SpeedyBee board with BLS ESCs.
dkemxr
(Dave)
June 29, 2024, 5:17pm
4
And flash Bluejay to the ESC’s to get RPM via Bdshot.
With the demise of BLHeli_32 this is a great option.
changed MOT_PWM_TYPE from Normal to DShot300, it helped, thanks!
Oli1
(Oli)
June 30, 2024, 9:24am
6
Do yourself a favor and use this alongside that .
Awesome, haven’t seen this before, thanks!
