Hello:
Does Ardupilot use terrain following?
If so, does it accept terrain data from DEMs or DSMs?
What formats is the data required to be in?
Thanks in advance.
Hello:
Thanks in advance.
This should help.
Click the first link for plane or the second link for copter.
[Edit] links may be swapped in different browsers
Hello Jan:
Thanks for the reply. I found the links, but neither link loads a page when clicked on.
Maybe these links work better:
Copter, Plane
If they still don’t load, try a different browser or computer. They do exist.
Short summary:
Yes, Ardupilot has a terrain following feature. The source of the terrain data in Mission Planner and MAVProxy is the global SRTM database with a 100m spacing between datapoints. Alternatively you can get terrain data here with a spacing down to 30m.
Hi Jan:
Many thanks for the new links! They work fine.
I read that ArduPilot references the SRTM database, which has a typical accuracy of around 10 to 20 meters. In addition, some areas may suffer from worse accuracy.
Is it possible to create a more accurate DSM/DEM using a local drone survey which can then be used by ArduPilot?
This practice is possible in DJI drones.
Thanks for your help.
